I was wondering if a customisable filament loading function could be added.
A one click loading for each extruded each with a custom profile where extruded size, filament size, temp, length and feed rate could be set.
So once set up. Every time you click load it uses that profile until you change it.
Reason is that most printers are fixed with load with 0.4 size nozzle which doesn't work well with 0.2 nozzle.
Stops panic of filament shredding and help with waste too by setting minimal length
