I have had three issues:
1. If I take a Solidworks STL and use the Import button, it will say that the object is too large for the build area. It will load it, but it will be invisible. It will then crash the program. However, if I load the same object by dragging it into the program, it will be fine. I assume this is a mm/inch issue but there is only a problem if loaded from the Import button.
2. I have had strange bridging connecting objects that should not be connected. If I go to the repair menu, it will complain about intersecting surfaces. SO maybe Solidworks is putting out bad STLs, but version 2.2.2 never had an issue with them.
3. I can't make each quality setting have its own print speed. I want higher quality settings to print more slowly. The program will not allow it.
