Rebekah_harper
Floating support in print preview
hiya team,
for some reason I have a few layers of support that is floating in mid air. I have attached the factory file so it should recreate it.
It spans between two holes across the front of the chassis. Why is this and how do I get it rid of it.
many thanks
Becky
THW10_022-FRONT CHASSIS.factory
(118.81 KiB) Downloaded 134 times
Re: Floating support in print preview
It looks correct to me, it's just inflated by 1mm since you have that in your settings
Rebekah_harper
but it's connected a gap between the two holes that's 50mm with nothing above it for it to support. I added the 1mm because of the features lower down.
I would have thought it would just extend the support 1mm either side of the holes not right accross. can remember this happeing in previous version.
It expands equally in all directions. Has always worked that way.
