Brim and Ooze Shield
Posted: Wed Jul 01, 2015 1:10 am
by Sinus
if i use Skirt / Brim with an Skirt offset from Part = 0.1 and 8 Outlines the Brim works fine. Now i want to have a Ooze shield too. The problem is now, the brim is now at the shield and not at my model. Iit possible do get brim on model and brim?
Regards Joerg
Re: Brim and Ooze Shield
Posted: Wed Jul 01, 2015 11:21 am
by DarthRevan
I've not found a way to do brim on the model while using an ooze shield. You can use a raft. :?
Posted: Mon Jul 06, 2015 7:32 pm
by KC_703
Raft would probably be the only way to attach the brim to the project rather than the ooze shield. Do you require the brim for anchoring the project to the bed? If not, then maybe a smaller ooze shield offset...
Or if you need the brim to create better adhesion of the project, lower the nozzle through the Z-Offset G-code setting... maybe a -.1 or -.2 value to help adhesion. There are additional strategies for better adhesion... try first layer settings (increase extrusion), no cooling, etc.
Posted: Thu Jul 09, 2015 2:04 am
by Rebekah_harper
Under layer you can do a lower height by % if it's an adhesion problem.
Posted: Thu Jul 09, 2015 2:09 am
by Sinus
Sorry the only thing i found, is the % for the first Layer. But this didn't help.
If i want to use Brim, i think brim shoud on the model and not on the shield.
Sinus
Posted: Thu Jul 09, 2015 3:06 am
by KC_703
First layer % and the z-code offset are different settings which I think have different results.
I'm not in front of my computer, but I believe it's the G-code tab that has the Z-offset. This will lower your hotend after its homed. The nozzle will be closer to the bed, therefore increasing the "squash"... Which will help with adhesion of the project. I think the difference is that there is no change to filament extrusion characteristics to achieve the fatter, oval first layer.
Again, I think the first layer % and the Z-offset are different... But could be wrong. From experience, I've had much better luck increasing adhesion through the Z-offset. Use .05-.1 increments.
Regardless, it would be nice to have the brim attached to the print and not the ooze shield.
Posted: Fri Dec 22, 2017 10:42 pm
by gearsawe
Yes this is an old topic and still a bug!
I am using the ooze shield as a draft shield to help contain the heat around a part. But cant have a shield and brim the model still!
turning on ooze shield and brim forces the brim to the outside of the model.
I have even tried to make 2 processes.
1. with 0 top/bottom layer 0 perimeter and 0% infill. Ooze shield on. No Brim
2. anther with 3 top/bottom layers, 2 perimeters and 20% infill. ooze shield off.
result is Model with brim and no ooze shield.
the only work around is make a model as a shied put a small gap at the bottom as a break in the perimeter( the small gap at the bottom allow the brim to also go on inside and around the part). The shield model has single wall extrusions applied.
Then another process for the model itself. This is a very time consuming processes to setup.
Posted: Thu Aug 16, 2018 10:18 am
by SusiT140V
Holy Cr@p!
THREE YEARS and this dumb bug STILL has not been fixed!!
Sorry for being 'all shouty', but I have had two days of nylon prints fail because of this.
Solution - either do what gearsawe suggested, or use Cura.
I have done the latter.
And don't even get me started on the mess they made to 'Save' when they "Fixed" it in 4.01...
I love S3D for its powerful simplicity, but this kind of bug really makes me seethe.
Can you tell?
Toodles, Mo... ;)
Posted: Tue Aug 15, 2023 4:01 am
by marius_tietz
I usually don't uncover 50 years old posts, but I just want to mention, that it is 2023 now and the problem still exists in the most recent version. :D
