jdengineering2015
One layer error
Hello
this is my first "big print" using simplify 3d (6 hours).
Im using a Wanhao duplicator 4s.
I think the slicer missed one of the layer as you can see in the attached pictures. What do you think that could be the problem??
hombrosuperior.STL
Stl file
(48.81 KiB) Downloaded 352 times
4s.factory
Factory file
(28.1 KiB) Downloaded 414 times
Re: One layer error
I don't see any issues with the gcode from the files you attached, so more likely the extruder had an issue for one layer. It can be caused by a lot of things. Inconsistent filament diameter, a tangle in the reel, a partial clog in the nozzle, etc.
Tetraodon
Re: One layer error
I was about to post the same thing - mine decided to forget a layer on the outside of the model, but the gcode preview looks to be fine.
Re: One layer error
the gcode preview doesnt lie. if its there in the preview then the code told your printer to print it.
DarthRevan
Re: One layer error
As everyone else has already pointed out, the gcode preview will show you if the code is wrong or your printer had a problem. The longer the print, the more chances there are for your printer to mess up. :(
KC_703
Re: One layer error
Looks like a machine or extrusion issue...
Have you tried other projects at which are the same height to check that the machine is okay? Or just try raising the extruder through that portion of the print and listen or observe any abnormalities.
Could be that the filament was "caught" on the reel...
jcullins
Re: One layer error
could be your table caught on something so did not move up to next layer.... I am new but just a thought
