Trax
Issue with prime pilars
Hello,
When I create 2 processes for two different extruders and set on pilar to NW and the other to NE it only prints the NW pilar, if I disable process one it creates the NW pilar of process two.
I remember a simmilar issue from the 2.x versions with brin, always only one of the processes created the brim and the other extruder did not.
I guess its the same bug, but you relly need to fix that as one ofcause would like to wipe booth nozzles...
PS: I haven't actually printed anything lust looked in the preview.
DarthRevan
Re: Issue with prime pilars
A single prime pillar can and does easily handle the priming of both nozzles.
KDan
DarthRevan wrote:A single prime pillar can and does easily handle the priming of both nozzles.
... except when the two materials won't adhere - which is the problem I'm having with ABS and HIPS. The prime pillar with alternating materials simply falls apart.
Kenny
With one pilar you only prime one extruder per layer, but you need to prime both extruders on each layer, I believe this is a bug.....
It primes both nozzles just fine with only 1 single prime pillar. It would be a waste of time to prime both extruders for every single layer. Now, if your plastics don't stick together, than that's another problem...
