Lulzbot TAZ 4 Dual Extruder: Not registering in 3.0
Posted: Sat Jul 04, 2015 8:08 pm
by Mudaseem
Hello,
When I go to add the TAZ 4 and set up dual extruders by adding another tool head manually, the dual extrusion wizard does not seem to recognize it and tells me to select another profile. This is how I did it previously in S3D 2.2.1
I also tried setting up an "other" profile by mimicking the TAZ 4 profile (plus another extruder) but the wizard still does not recognize it.
Any thoughts?
Thanks,
MM
Re: Lulzbot TAZ 4 Dual Extruder: Not registering in 3.0
Posted: Sun Jul 05, 2015 12:30 pm
by JoeJ
There are a lot of new convenience features that S3D included in their dual extrusion profiles now. Many of these items are exactly what makes it so easy to use the dual extrusion wizard and easily reconfigure things as needed. If you make a profile by hand, it's likely it will be missing some of these new settings.
Easiest thing to do would probably be to load a similar dual extrusion profile (such as Leapfrog Creatr Dual) and then just adjust the other settings as needed.
