Solid infill area
Posted: Sun Jul 05, 2015 5:35 am
You should give the option to the user to extend the solid infill area when it comes to parts that are in the middle of the print.
Sometimes when you have a 10% or less infill, the solid parts fail just because there is nothing there to support it. In this cases the only solution is to increase the infill density, while if there was an option to extend the solid infill area would have solved the problem.
