[DONE] Multi material Infill
Posted: Sun Jul 05, 2015 8:48 pm
by Scott Lograsso
I am very new to Simplify 3d, My first print finished 20 minutes ago, but I am certainly a huge fan. I struggled with it a bit but that was my printer. I noticed right away in 3.0 the option to select extruder, Right or left as I was setting up advanced infill I also noticed the internal and external infill has been separated which is AWESOME!!!!!!!!!!.
In the future, the very near future, I will be making functional car parts that will utilize a different material for the sparse in fill. If I could simply select which extruder does external and which does internal ....... well I could hug you all...... I could already.
I am a very mechanical human and have been fine tuning machines for quite some time ( race cars ). The first moments in the advanced settings were like rolling on the professional stage I was longing for Thank you!!!! Please consider my request. This feature would save many professionals a lot of time as I can simply design the part and then adjust infill settings instead of designing the outer shell and then inner structure and then print and test and then then redesign..........
If this is option is already available please forgive me for wasting time. I am very new to this software.
Thank you so much,
Scott Lograsso
Re: Multi material Infill
Posted: Wed Jul 08, 2015 9:34 am
by JoeJ
Yes, it's already in there. The primary extruder that you select on the Layer tab is used for the exterior of your model (i.e. perimeters and outer solid layers). The infill extruder that you select on the Infill tab is used for the interior fill.
