I'm having issues printing sharp overhang corners, specifically those of these heart gears. I thought it was an overhang thing or that it needed tweaking the temperature so I did a temperature tower - 225 to 210 and all of the overhangs look good. I thought it might be acceleration so I have gcode at the beginning to lower it to 1000, and the print speed is already at "Fine PLA" speed in Simplify3D which works fine for other things but it doesn't change things here. I even lowered the speed manually to 50% of that for the second half of the print I have in the pictures with the same result. The one thing I notice as it prints is that the print head sometimes stops at the tip of each corner and puts a little drop of material, which seems weird to me and I'm not sure what in the slicing would make it do that.
I was going to embed the pictures but its easier to tell in higher res.
I'm pringing with Simplify3D 2.2.2 on a Kittaz using InPla Taulman3D White.
Thanks for the help!
