gcode start
Posted: Tue Jul 07, 2015 4:03 pm
by lines11
i like to start printing like in cura:
G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
;Put printing message on LCD screen
M117 Printing...
;Layer count: 14
;LAYER:0
M106 S255
G0 F9000 X152.66 Y296.52 Z0.70
;TYPE:SKIRT
after homing (g28) raise nozzle (z15) and then go to start coordinate in all 3 axis (G0 F9000 X152.66 Y296.52 Z0.70).
Is there a option in smplify3d?
Thank you
best regards
Re: gcode start
Posted: Tue Jul 07, 2015 6:29 pm
by JoeJ
Just put that in your starting script (click "edit process settings", and click on the Scripts tab)
Re: gcode start
Posted: Wed Jul 08, 2015 8:39 am
by lines11
Thank you, I know what you mean, but the first point, in that case x152,66 and y 296,52 is on every model another, because every model has another size. The slicing software calculates that point, so I mean I can't write it in my start gcode script.
Re: gcode start
Posted: Thu Jul 09, 2015 6:24 am
by JoeJ
Yes, and the software will automatically include that. Just add the commands below into your starting G-Code script
Code: Select all
G28 Z0 ; move Z to min endstops
G1 Z15.0 F9000 ; move the platform down 15mm
G92 E0 ; zero the extruded length
G1 F200 E3 ; extrude 3mm of feed stock
G92 E0 ; zero the extruded length again
G1 F9000
M117 Printing
