Horizontal size compensation?
Posted: Wed Jul 08, 2015 2:56 am
by amcutem
I hope this is not a stupid question, but let's say I printed a 30mm cylinder with a 10 mm hole, and then I added a 1mm value.
I think I'm right if I say that the outer cylinder will then be 32mm, but then I don't know what will happen to the 10MM hole?
I guess it can only become 12mm?
Re: Horizontal size compensation?
Posted: Wed Jul 08, 2015 5:55 am
by JoeJ
No, it goes inward. If you put a positive value in for the size compensation, then the part grows outward everywhere. So the hole would become 8mm.
If you put in -1mm for the size compensation, then the outer cylinder would become 28mm and the hold would become 12mm
Posted: Wed Jul 08, 2015 9:59 am
by C-line
This feature can be a bit confusing at first.
The way I like to think of it is as if your part was a sponge. If you use a positive value for Horizontal Size Compensation it's like wetting the sponge: it grows in all directions, with the outer perimeters moving outward and the inner perimeters moving inward. If you use a negative value it's like drying out the sponge: it shrinks in all directions, with the outer perimeters moving inward and the inner perimeters moving outward.
Hope this helps!
Posted: Wed Jul 08, 2015 10:41 am
by dsegel
Also, because the dimensions are changing everywhere (in X and Y) you usually want to use very small values, like 0.1mm or even less. If you need to overcome a larger fit issue than that you may be better off just scaling the entire model.
Posted: Wed Jul 08, 2015 2:10 pm
by KC_703
Yes... positive inflates and negative shrinks. Sponge is good analogy.
Best way to understand this may be to see it for yourself. Load up a captive planetary gear, slice, view the preview... then re-slice and preview using different horizontal size compensation.
