MendelMax3 w/ Dual Extruders...Dual Extrusion Wizard
Posted: Wed Jul 08, 2015 9:51 pm
by morreale
Which profile do I need to be able to use the Dual Extrusion Wizard with the MendelMax3? Do I need to create them manually?
Thanks.
Re: MendelMax3 w/ Dual Extruders...Dual Extrusion Wizard
Posted: Wed Jul 08, 2015 10:53 pm
by KeyboardWarrior
From the Tutorial:
https://www.simplify3d.com/support/tuto ... extruders/
Not seeing your printer in the Dual Extrusion Wizard/Configuration Assistant.
To create a profile for your printer, please select the option for “Other” in the Configuration Assistant and then enter in your machine profile. Using this custom profile, you can set up your print using the second portion of this tutorial (on how to print a feature with a different extruder).
Please feel free to contact Support for help setting up a profile for your printer to use the Dual Extrusion Wizard.
I'd recommend contacting support.
Posted: Thu Jul 09, 2015 6:47 am
by JoeJ
Or just use one of their other pre-configured profiles as a template (for example, Leapfrog Creatr Dual) and then just make whatever additional changes you need to that
Posted: Thu Jul 09, 2015 11:22 am
by morreale
thanks for the info
Posted: Thu Jul 09, 2015 6:27 pm
by morreale
i have sent a message to support so we'll see what they say.
I have created a custom profile and replicated all the settings in the other dual extruder profiles and still get the error that the profile does not support dual extrusion wizard
Posted: Sun Sep 20, 2015 8:23 pm
by AxxAxx
I have the same problem with the dual extrusion wizard with my own reconfigured printer. Did you find any solution?
//AxxAxx
Posted: Mon Sep 21, 2015 10:10 am
by JoeJ
Yes - read above. Either contact support or use one of the other profiles as a template (like the Leapfrog Creatr Dual)
