tool change retraction
Posted: Fri Jul 10, 2015 10:37 am
by ronnien55
Under the Advanced Tab there is the tool change retraction. It does not seam to work correctly. I cannot input a negative tool retraction only positive, but retract is a negative number not positive. the restart distance can be positive or negative all though i do not understand retracting when you are trying to extrude what you retracted. Am i looking at they wrong or is there a mistake in values in this section?
Re: tool change retraction
Posted: Fri Jul 10, 2015 11:17 am
by KeyboardWarrior
Can you post a factory file (File-->Save Factory File As)
