Return to print monitor view
Posted: Fri Jul 10, 2015 10:34 pm
by idover
Hello, once a print is underway and Simplify3D is showing the current print I am able to leave that view and return to the model view. However, I can't figure out how to get back to the view that monitors the current print. Is that possible?
Thanks!
Isaac
Re: Return to print monitor view
Posted: Sat Jul 11, 2015 7:32 am
by BaudR8
Once you leave the print preview window, I do not believe you can return to it unless you just slice again. As long as you slice with the same settings you did with the current print, it should bring the live view back to the current position the print is at
