Layers keep cracking? help
Posted: Sun Jul 12, 2015 7:19 pm
by hansen644
Pic attached. Layers keep cracking and not sure how to fix it? 225 degrees ABS speed about 75% No cooling. bed at 107 degrees.
using a smartone 200 printer.
Re: Layers keep cracking? help
Posted: Sun Jul 12, 2015 7:49 pm
by JoeJ
Try a lower layer height. It looks like your layers aren't really being squished together enough to bond.
Posted: Sun Jul 12, 2015 8:01 pm
by hansen644
Using 2.0 layer height
Posted: Sun Jul 12, 2015 8:28 pm
by hansen644
Sorry correction I thought it was 2.0 but look like I had it at 3.0 by misstake. will try it out now
Posted: Mon Jul 13, 2015 12:10 am
by jimc
also your temp for abs looks really low. im sure at that temp you have poor layer adhesion. run 245-255.
Posted: Mon Jul 13, 2015 9:55 am
by tenaja
jimc wrote:also your temp for abs looks really low. im sure at that temp you have poor layer adhesion. run 245-255.
The actual temperature varies greatly between machines, but 225 seems pretty low to me, too.
Posted: Mon Jul 13, 2015 12:44 pm
by jimmybuckets
I just printed my first role of abs and had very good luck. Printed at 250 with a bed temp of 105
Posted: Mon Jul 13, 2015 9:37 pm
by KC_703
The cracking is from poor layer adhesion. Which is typically from low extrusion temp and too much cooling.
I agree with others 225 seems pretty low for ABS and 240-245C works best for me also... but it differs by brand and even color.
Cooling seems a bit high for ABS also. ABS seems to have a tendency to contract as it cools. I like to keep cooling between 30-50% and blipping to 80% for bridging.
Again, you'll have to experiment to find the sweet spot for your printer.
Posted: Tue Jul 14, 2015 4:58 pm
by jimmybuckets
I don't use any cooling for abs
