What usage restrictions are there with s3d?
Apparently (from other threads) it requires on line activation, but dos it requires permanent Internet connection?
Is it a single machine license (to be installed on one PC only) or a single user license (to be installed on all PC's the user owns)?
If its a single machine license can the license be moved from one PC to another?
And if so, does this also work if the current PC dies (HDD broken no backup), how than the software can be used again with a new PC or new clean OS on old PC.
Is there a test version available? If no how do you handle return requests if user is not satisfied with the product?
And in the case you go bankrupt how can the users continue using their purchased software? Can you guarantee to release a patch to remove any activation requirements in case you close down the activation servers due to whatever reasons?
Many questions...
