First layer vs. extrusion width
Posted: Tue Jul 14, 2015 11:17 am
by dewme5
I'm printing on a Rostock Max V2.
.5 nozzle, .4 first layer height. extrusion steps are calibrated, Printing a 20mm cube, using 2 bottom layers, and single corkscrew walls.
When extrusion width is left on automatic, the box goes gray, and .60mm is used. However, the measured width ends up being .81mm. So, I adjusted the extrusion multiplier from 100% down to 86%. Now, perfect .60mm walls, but the layers have gaps. I've adjusted infill extrusion width from 100% to 200% with no noticeable change.
How can I keep the .60mm walls, while also getting a great first layer?
The left shows 86%, right 100% extrusion multiplier, leaving .60mm and .81mm walls respectively.
Re: First layer vs. extrusion width
Posted: Tue Jul 14, 2015 4:07 pm
by KeyboardWarrior
dewme5 wrote:I'm printing on a Rostock Max V2.
Can you got to File-->Save Factory File and post that?
Also, can you post pictures of the measurements you're using?
Lastly, is the profile you're using based off of the Simplify3D 3.0 profile?
Posted: Tue Jul 14, 2015 4:44 pm
by dewme5
KeyboardWarrior wrote:[
The profile is one I found online. The Simplify3d profile was not even close to good results.
Pictures of the measurements I'm using, if I understand what you are asking for correctly. 20mm cube, printed single wall in spiral. The finish looks excellent and adhesion is great.
Posted: Tue Jul 14, 2015 8:30 pm
by dewme5
I think I have found a portion of the answer I was looking for. Researching through the Slic3r manual, I come across
Extrusion Width is the thickness of a single filament extruded either in free air or above a surface. It's not the distance of two adjacent paths since some overlap will be generally applied in order to get better bonding.
So my biggest issue, was a misunderstanding of what extrusion width actually meant. I followed someones suggestion on dialing in one specific aspect of the settings, which lead me astray.
Posted: Wed Jul 15, 2015 12:01 am
by KeyboardWarrior
dewme5 wrote:I think I have found a portion of the answer I was looking for. Researching through the Slic3r manual, I come across
In Simplify3D Extrusion Width effects your toolpaths. If you have issues with your lines not being connected, then increasing the Extrusion Multiplier is recommended.
