How to slow down first layer skirt speed?
Posted: Thu Jul 16, 2015 8:02 am
HI how do I slow down the outline that the printer makes that goes around the print before it starts the first layer?
Simplifying the 3D Experience!
https://forum.simplify3d.com/
Chekhov has a good dialog driven solution. Below is an alternate solution if you prefer to use a single profile for printing.chekhov wrote:Have the same issue. I tried to trick it with Two separate Processes in one of them printer's Infill supports speed is set to desired speed
My default profile has no brim and it uses the speed reduction in the "first layer speed" setting with no problems. When printing a brim the speed reduction from "first layer speed" is not enough. If I reduce the first layer more, the features print too slow.brian442 wrote:This would do the exact same thing as modifying the "first layer speed" setting. They both change the speed of the entire first layer, so I'm not sure why you wouldn't just use the option already in S3D??
