For several months, a few of us in the Smoothie community have been experiencing a weird symptomology when using Smoothie with Simplify3d. At some point, and it will be the same point for a given gcode file every time, the printer will stop moving and the extruder will sing at a constant frequency without moving. For some models, the failure point is early, sometimes it's two hours or more into a print.
The problem:
* Only happens when Simplify3D is the slicer
* Only happens when running from SD card (as opposed to over USB)
* Always involves an circle/elipse or high detail model.
The current theory of the smoothie devs is that Simplify3D is slicing moves into segments smaller than the useful resolution from the printers.
Does anyone else have any experience with this? Some flags to modify the slicing to avoid these small moves? Apparently, the Smoothie team has reached out and received no response or help.
EDIT: I forgot to describe the symptomology
