Hello, I was told when I purchased this software that it would contain support for the ultimaker 2 Dual Extrusion. I attempted to use the standard profile..."Ultimaker 2" but it didn't support Dual extrusion, and most recently I attempted to make a custom printer profile and that didn't support dual extrusion. Is there any way to actually use this software to support dual extrusion with the ultimaker 2?
I use it in my dual head setup (https://www.youmagine.com/designs/dual-head-ultimaker2) so YOU WILL NEED TO REMOVE the toolhead change script in the script tab !!! And you'll need to change the XY g-code offset, and I may be forgetting something Use at your own risk
