ddnguyen_278
Multi-Process prints Raft and Support problems
When printing with multiple processes on a single model with the raft option on, some of the supports are left orphaned outside the raft area and are printed above air sometimes. There seems to be some issue with raft generation and support generation in multi-process prints.
BaudR8
Re: Multi-Process prints Raft and Support problems
Could you post a factory file up? It would help others see waht's going on, just go to File > Save Factory file as... and it will save all of your current processes as well as imported models
ddnguyen_278
Will do, here's the factory file note the support for her right arm, they are being printed outside the raft in mid air initially which causes them to fail. I'm using 2 processes because I want the upper body to be printed at high detail while lower body at medium detail.
figure_of_a_dancer_archive.factory
(8.51 MiB) Downloaded 281 times
KC_703
That's an interesting one... I don't have a good reason for why the support is starting in mid-air, but increasing the raft offset to 8 seems put the supports on the raft.
