v3.0 - Support missing half -- v2.2 Support OK.
Posted: Sat Jul 25, 2015 6:11 pm
What's going on with Simplify 3.0 version compared to the 2.2 version?
The 3.0 version produces about 1/2 missing support structure -- while the 2.2 version works fine.
Simplify 3.0 version, the support structure is asymmetrical and missing on the right side of part.
BFB file here:
https://drive.google.com/open?id=0B07eq ... mVMaWFSSzA
v3.0 Snapshot with missing support on right side.
https://drive.google.com/open?id=0B07eq ... nBtVXhUMVU
In Simplify 2.2 version -- the support structure is symmetrical across the bottom of the part.
BFB file here:
https://drive.google.com/open?id=0B07eq ... npIQmhUdVk
v2.2 snapshot with support OK.
https://drive.google.com/open?id=0B07eq ... i1lNTI0M2s
The profile info for the 3.0 and 2.2 support versions are similar.
So what is causing the missing support structure problem in 3.0 version??
3.0 BFB header config...
; G-Code generated by Simplify3D(R) Version 3.0.0
; Jul 25, 2015 at 3:57:17 PM
; Settings Summary
; processName,Process1
; applyToModels,hholder3_4
; profileName,PLA Thin Wall-Raft-Dense Support
; profileVersion,2015-07-25 14:50:42
; baseProfile,PLA Thin Wall-Raft-Dense Support_ORIG_EXPORT (modified)
; printMaterial,PLA
; printQuality,Medium
; printExtruders,
; extruderName,Primary Extruder
; extruderToolheadNumber,0
; extruderDiameter,0.5
; extruderAutoWidth,0
; extruderWidth,0.6
; extrusionMultiplier,0.9
; extruderUseRetract,1
; extruderRetractionDistance,1
; extruderExtraRestartDistance,0
; extruderRetractionZLift,0
; extruderRetractionSpeed,1800
; extruderUseCoasting,0
; extruderCoastingDistance,0.2
; extruderUseWipe,0
; extruderWipeDistance,5
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,6
; bottomSolidLayers,3
; perimeterOutlines,2
; printPerimetersInsideOut,0
; startPointOption,2
; startPointOriginX,0
; startPointOriginY,0
; startPointOriginZ,300
; sequentialIslands,0
; spiralVaseMode,0
; firstLayerHeightPercentage,100
; firstLayerWidthPercentage,100
; firstLayerUnderspeed,0.8
; useRaft,1
; raftExtruder,0
; raftLayers,2
; raftOffset,3
; raftSeparationDistance,0.25
; raftInfill,90
; disableRaftBaseLayers,1
; useSkirt,0
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,6
; skirtOffset,4
; usePrimePillar,0
; primePillarExtruder,999
; primePillarWidth,12
; primePillarLocation,7
; primePillarSpeedMultiplier,1
; useOozeShield,0
; oozeShieldExtruder,999
; oozeShieldOffset,2
; oozeShieldOutlines,1
; oozeShieldSidewallShape,1
; oozeShieldSidewallAngle,30
; oozeShieldSpeedMultiplier,1
; infillExtruder,0
; internalInfillPattern,Rectilinear
; externalInfillPattern,Rectilinear
; infillPercentage,100
; outlineOverlapPercentage,15
; infillExtrusionWidthPercentage,100
; minInfillLength,5
; infillLayerInterval,1
; infillAngles,45,-45
; overlapInfillAngles,0
; generateSupport,1
; supportExtruder,0
; supportInfillPercentage,40
; supportExtraInflation,1
; denseSupportLayers,0
; denseSupportInfillPercentage,30
; supportLayerInterval,2
; supportHorizontalPartOffset,0.6
; supportUpperSeparationLayers,2
; supportLowerSeparationLayers,1
; supportType,0
; supportGridSpacing,4
; maxOverhangAngle,65
; supportAngles,0
; temperatureName,Primary Extruder Temperature
; temperatureNumber,0
; temperatureSetpointCount,1
; temperatureSetpointLayers,1
; temperatureSetpointTemperatures,230
; temperatureStabilizeAtStartup,1
; temperatureHeatedBed,0
; temperatureRelayBetweenLayers,0
; temperatureRelayBetweenLoops,0
; fanLayers,1,2
; fanSpeeds,0,60
; blipFanToFullPower,0
; adjustSpeedForCooling,1
; minSpeedLayerTime,4
; minCoolingSpeedSlowdown,80
; increaseFanForCooling,1
; minFanLayerTime,4
; maxCoolingFanSpeed,100
; increaseFanForBridging,0
; bridgingFanSpeed,100
; use5D,0
; relativeEdistances,0
; allowEaxisZeroing,0
; independentExtruderAxes,0
; includeM10123,1
; stickySupport,0
; applyToolheadOffsets,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; overrideMachineDefinition,0
; machineTypeOverride,0
; strokeXoverride,230
; strokeYoverride,275
; strokeZoverride,210
; originOffsetXoverride,115
; originOffsetYoverride,190
; originOffsetZoverride,0
; homeXdirOverride,-1
; homeYdirOverride,-1
; homeZdirOverride,-1
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
; overrideFirmwareConfiguration,1
; firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
; GPXconfigOverride,r2
; baudRateOverride,115200
; overridePrinterModels,0
; printerModelsOverride
; startingGcode,;,; *** STARTING G-CODE ***,;,; *** Warming Extruder ***,; Select extruder warm purge,; BfB-style,M104 S[extruder0_temperature],M542,M551 P64000 S900,M543,;,; Destring steps,M227 P3200 S3200,; Disable destring,M228 P0 S163,; Destring speed,M227 S768 P768,; Turn off cooling fan,M107,;,; Turn on extruder1 speed S,M108 S200,;
; layerChangeGcode,
; retractionGcode,
; toolChangeGcode,
; endingGcode,;,; All extruders cool to 0 temp.,M104 S0,M204 S0,M304 S0,;,; DONE Paused,M226,; Press Esc to lower bed.,; Press Esc AGAIN to main menu
; createX3G,0
; celebration,0
; celebrationSong,Random Song
; createMB5G,0
; postProcessing,{STRIP "M82"},{STRIP "G90"},{REPLACE "M107" "M107"},{REPLACE "M106
;" "M106
;\n;"},{REPLACE "M103" "M103"},{TOOL1REPLACE "M101" "M201"},{TOOL2REPLACE "M101" "M301"},{STRIP "T0"},{STRIP "T1"},{STRIP "T2"},{EXTENSION "bfb"}
; defaultSpeed,1500
; outlineUnderspeed,0.9
; solidInfillUnderspeed,0.9
; supportUnderspeed,1
; rapidXYspeed,4500
; rapidZspeed,30000
; minBridgingArea,50
; bridgingExtraInflation,0
; bridgingExtrusionMultiplier,1
; bridgingSpeedMultiplier,1
; filamentDiameter,3
; filamentPricePerKg,20
; filamentDensity,1.25
; useMinPrintHeight,0
; minPrintHeight,0
; useMaxPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; diaphragmLayerInterval,20
; robustSlicing,1
; mergeAllIntoSolid,0
; onlyRetractWhenCrossingOutline,1
; retractBetweenLayers,1
; useRetractionMinTravel,0
; retractionMinTravel,3
; retractWhileWiping,0
; onlyWipeOutlines,1
; avoidCrossingOutline,0
; maxMovementDetourFactor,3
; toolChangeRetractionDistance,12
; toolChangeExtraRestartDistance,-0.5
; toolChangeRetractionSpeed,600
; allowThinWallGapFill,1
; thinWallAllowedOverlapPercentage,10
; horizontalSizeCompensation,0
M107
2.0 BFB header config...
; G-Code generated by Simplify3D(R) Version 2.2.2
; Jul 24, 2015 at 6:17:50 PM
; Settings Summary
; processName,PLA Thin Wall-Raft-Dense Support
; profileLabel,PLA Thin Wall-Raft-Dense Support_2015_6_10.fff
; printMaterial,PLA
; extruderWidth,0.6
; extruderUseWipe,0
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,6
; spiralVaseMode,0
; useRaft,1
; raftExtruder,0
; raftLayers,2
; raftOffset,3
; raftInfill,90
; useSkirt,0
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,6
; skirtOffset,4
; infillExtruder,0
; minInfillLength,5
; randomInfillStartPoint,0
; generateSupport,1
; supportExtruder,0
; supportInfill,40
; denseSupportInfill,30
; supportAngles,0
; fanLayers,1,2
; fanSpeeds,0,60
; minFanLayerTime,4
; use5D,0
; includeM10123,1
; stickySupport,0
; detectArcs,0
; arcReplaceG2G3,0
; arcRadialCompensation,1
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; layerChangeGcode,
; toolChangeGcode,
; createX3G,0
; celebration,0
; createMB5G,0
;" "M106
; defaultSpeed,1500
; rapidXYspeed,4500
; rapidZspeed,30000
; minPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; robustSlicing,1
; useRetractionOozeRate,0
; retractionOozeRate,100
M107
BFB file here:
BFB file here:
; Settings Summary
; printMaterial,PLA
; printExtruders,
; extruderWidth,0.6
; extruderUseWipe,0
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,6
; spiralVaseMode,0
; useRaft,1
; raftExtruder,0
; raftLayers,2
; raftOffset,3
; raftInfill,90
; useSkirt,0
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,6
; skirtOffset,4
; usePrimePillar,0
; useOozeShield,0
; infillExtruder,0
; minInfillLength,5
; generateSupport,1
; supportExtruder,0
; supportType,0
; supportAngles,0
; fanLayers,1,2
; fanSpeeds,0,60
; minFanLayerTime,4
; use5D,0
; includeM10123,1
; stickySupport,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; layerChangeGcode,
; retractionGcode,
; toolChangeGcode,
; createX3G,0
; celebration,0
; createMB5G,0
;" "M106
; defaultSpeed,1500
; rapidXYspeed,4500
; rapidZspeed,30000
; minPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; robustSlicing,1
M107
; Settings Summary
; printMaterial,PLA
; extruderWidth,0.6
; extruderUseWipe,0
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,6
; spiralVaseMode,0
; useRaft,1
; raftExtruder,0
; raftLayers,2
; raftOffset,3
; raftInfill,90
; useSkirt,0
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,6
; skirtOffset,4
; infillExtruder,0
; minInfillLength,5
; generateSupport,1
; supportExtruder,0
; supportInfill,40
; supportAngles,0
; fanLayers,1,2
; fanSpeeds,0,60
; minFanLayerTime,4
; use5D,0
; includeM10123,1
; stickySupport,0
; detectArcs,0
; arcReplaceG2G3,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; layerChangeGcode,
; toolChangeGcode,
; createX3G,0
; celebration,0
; createMB5G,0
;" "M106
; defaultSpeed,1500
; rapidXYspeed,4500
; rapidZspeed,30000
; minPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; robustSlicing,1
M107
