Makerbot Rep2 Start Purge G code
Posted: Sun Jul 26, 2015 1:29 am
by CT4
I need to extend the time that the nozzle purges off the build plate at the start of the print. My start code is this. Please can someone let me know what I edit to achieve this.
; **** Replicator 2 start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-159 Y-95 Z30 F9000 ; move to wait position off table
M126 S[fan_speed_pwm]
M133 T0 ; stabilize extruder temperature
G92 A0 ; zero extruder
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-140 Y-70 Z0.15 F1200 ; slow wipe
G1 X-135 Y-65 Z0.5 F1200 ; lift
Re: Makerbot Rep2 Start Purge G code
Posted: Sun Jul 26, 2015 1:40 pm
Change this line:
The value 25 signifies 25 mm of extrusion ( or I should say I think its 25mm) ....adjust accordingly.
G1 is the instruction for "move". Enn is the parameter for the amount to extrude. And F is the parameter for the feed rate.
See here for reference: http://reprap.org/wiki/G-code
Posted: Sun Jul 26, 2015 4:38 pm
by CT4
Thank you
