Page 1 of 2
Full Grid vs Rectilinear Infill?
Posted: Mon Jul 27, 2015 10:29 am
by mitchfx
What are the main differences between the classic Rectilinear infill and the new Grid option? Are there cases where you would want to use one vs the other?
Re: Full Grid vs Rectilinear Infill?
Posted: Mon Jul 27, 2015 11:17 am
by jimc
Grid prints on every layer. Rectilinear does not. Rectilinear is a mesh where grid is solid.
Posted: Tue Jul 28, 2015 12:20 am
by mitchfx
How would this differ from using rectilinear with the "print every infill angle for each layer" checkbox ?
Posted: Tue Jul 28, 2015 1:38 am
by jimc
Its the same thing.
Posted: Tue Jul 28, 2015 9:56 am
by mitchfx
Wonder why there are two different options then. Seems redundant unless there are other things that set them apart.
Posted: Wed Dec 16, 2015 12:33 pm
by handsonstance
If I'm printing at 100% infill, does the 'print every infill angle for each layer' box become redundant under rectilinear?
Posted: Thu Dec 17, 2015 7:42 am
Well I'm not sure if redundant is the right work. More like not needed. You're just wasting time by doing that and you get the same amount of plastic. I would recommend using 100% infill with the "print every infill angle on each layer" option disabled. That will be quicker.
Posted: Sat Jun 24, 2017 4:44 pm
by mitchfx
CompoundCarl wrote: I would recommend using 100% infill with the "print every infill angle on each layer" option disabled. .
100% infill? Wow!
Posted: Mon Jun 26, 2017 7:17 am
by wirlybird
One thing I think I noticed was printing grid at say 30% and then print rectilinear at 30%and the grid has wider spacing. I have not gone back to test.
Posted: Mon Jun 26, 2017 8:06 am
I wouldn't expect different fill styles to have exactly the same pitch when set to the same percentage fill. What is there to test?
