Ditto Print
Posted: Thu Jul 30, 2015 2:24 pm
by zanthor
My printer supports Ditto Print, but I'd really like to see it supported in S3D because there are limitations that simply can't be overcome with the stock ditto print...
Now that said, I don't even know if this is possible... but the part I want to change are extruder settings, I'm printing with two different colors and often I find that one needs a little more extrusion than the other, or slightly different temperatures. For the most part I can work around this by pairing "good" filaments together, but when I need a dozen red and a dozen black of an item, its a bummer to have to print them seperately because there's a 10C delta between the filament adhesion sweet spots...
Re: Ditto Print
Posted: Fri Jul 31, 2015 4:52 am
by JoeJ
I thought you could already use alternate slicers with the Ditto printers? For example, doesn't this thread talk about using Slic3r with the Ditto printer?
http://45.79.101.135/forum/?page_id=5/s ... c3r-v0-9-7
I imagine you could just use those exact same settings to create a profile in S3D for the Ditto
Give it a try and let us know how it works!
Re: Ditto Print
Posted: Fri Jul 31, 2015 8:03 am
by Umpa
Am I right that you are taking about ditto printing as in the type that sailfish gives you ?
Re: Ditto Print
Posted: Fri Jul 31, 2015 3:48 pm
by zanthor
Umpa wrote:Am I right that you are taking about ditto printing as in the type that sailfish gives you ?
Yes.
Re: Ditto Print
Posted: Sat Aug 01, 2015 5:16 am
by Umpa
The data that is for 1 extruder is passed to the other. S3d can't do anything for that.
