reset in smoothieboard
Posted: Mon Aug 03, 2015 4:28 pm
by AndersE
According to smoothieware it is supposed to reset the board if you type "reset" as a gcode command
but simplify just say "command received" and nothing happens.
Am i doing something wrong?
Re: reset in smoothieboard
Posted: Tue Aug 04, 2015 6:41 am
by JoeJ
That sounds like an issue with the firmware. There isn't much else to do in S3D than to type "reset" into the communication window and press Send. After that it's up to the firmware to choose how to handle the command.
Posted: Tue Aug 04, 2015 3:35 pm
by AndersE
I got a response from A.Wolf, he said that Simplify seems to not support unknown g-codes like "reset"
I haven't tried any other soft, but he say pronterface happily take "reset" as command.
Posted: Wed Aug 05, 2015 6:14 am
by JoeJ
Well that's not true at all. I just ran some tests and S3D absolutely DOES send the "reset" command correctly. The software is going to send whatever command you type in, but it's up to the firmware to determine how to handle it. So the software is definitely sending the command to the printer, I can confirm that much. There is no reason to say that it doesn't support unknown commands - it will send whatever you type regardless of if it "knows" the command.
Posted: Wed Aug 05, 2015 7:25 am
I've tested this as well, and S3D sends any command you type
