Varibale Layer Speeds
Posted: Tue Aug 04, 2015 4:28 am
by jrpmedia
So, we know that slowing down printing speed causes less vibration and the horizontal surface quality becomes brilliant ! :-)
But I don't want to do my Whole print at that slow speed of 20mm/s as it takes days.
Is it possible to just set the Top Solid Layers to 20mms ... and the rest of the models Bottom Solid Layers, Infill, Support, Outline/Perimeter Shells to 80mm/s ?
A bit like building the pyramids ... use rough blocks for the base and infill, then smoother finer layers for the coating (in this case horizontal layers)
Re: Varibale Layer Speeds
Posted: Tue Aug 04, 2015 6:44 am
by JoeJ
On the Other tab, you can set speed modifiers for the outlines, top solid layers, support structures, rapid movements, etc. So just adjust the one for the solid infill (i.e. top solid layers) and that way only that portion of your print will slow down.
Posted: Tue Aug 04, 2015 8:26 am
by jrpmedia
JoeJ wrote:On the Other tab, you can set speed modifiers for the outlines, top solid layers, support structures, rapid movements, etc. So just adjust the one for the solid infill (i.e. top solid layers) and that way only that portion of your print will slow down.
Many thanks Joe :-)
Will test and come back ASAP.
