Prusa with Dual bowden extruder: tool change g-code ?
Posted: Tue Aug 04, 2015 5:26 am
he guys,
i need your help
I have a prusa r2 evo (from an italian modder, nicolap) with two bowden extruder and i need to print using two colors, of course.
My 3d printer need to rectract 100 mm from an extruder before extrude other 100 mm of news color.
Until today i used repetier host with cura engine but i think that simplify (especially in supports) is best then cura so i need learn print with two colors.
In cura engine i have start and end gcode (the same in simplify) and i've two goce:
- one before change tool;
- one after change toool.
But in simplify there is only one gcode "tool change" and i don't know what insert in this gcode.
In cura these are my gcode:
preSwitchExtruderCode
; EVO prima di cambio estrusore
M117 Cambio colore
G60 ; memorize coordinate
G1 X-25 F10000 ; home x axis
G91 ; relative positioning
G1 F2000 E-100 ; retract old color
postSwitchExtruderCode
; EVO dopo di cambio estrusore
G1 F2000 E70 ; charge new color
G1 F300 E30 ; infill melt-zone
G1 F200 E20
G90
G61 x ; recall x coordinate
G92 E0 ; reset extruder position
G1 F2700 E-2 ; prevent oozing
Some guys suggested me to place in simplify "tools change" the entire g-code, so:
;tool change
M117 Cambio colore
G1 F200 E20
G90
If i do this and set two process with two extruder in simplify the result is the following;
- the print start with the right extruder (A) (before start it retract and extrude again 100 mm);
- when arrive the moment that i need to print with the other color happen that the extruder A retract 100 mm (and this is good) and after the extruder A extrude 100 mm of the same pla (THIS IS NO GOOD) and after the extruder B start to print ... and this is no good.
In my printer i've a flux to manage two colors.
The question is: what kind of gcode i need to place there to:
- retract 100 mm from extruder A
- extrude 100 mm from estruder B
In this video u can see my printer.
https://www.youtube.com/watch?v=WaT8dyNXEkY
Thank u for the help, really.
Michele (from Italy)
i need your help
M117 Cambio colore
G1 F200 E20
G90
;tool change
M117 Cambio colore
G1 F200 E20
G90
