FF Dreamer stepper values error?
Posted: Tue Aug 04, 2015 11:03 am
by GergK
Hi All,
Could everyone tell me, how can I check (and/or reset) the stepper vaules in Flashforge Dreamer?
I have problems with the followings:
- The head moving is larger than gcode script, therefore it makes 5% bigger size parts (only x,y directions),
- when the machine doing the starting script, running out of hard limit, and makes hard noise
- when I print with dual extruders, they are looks misalignment, however the tool tip distance values looks correct.
Of course, I could resize the models before print, and manually adjust the tip distance in g-code, but I think these steps wont be the resolve the original problem...
Im using the latest firmvare..
Thank you for your help,
Greg
Re: FF Dreamer stepper values error?
Posted: Tue Aug 04, 2015 12:12 pm
by JoeJ
Are you sure you have the right firmware on there? I'm not sure you can set the steps per mm or toolhead offsets for the flashforge dreamer. I thought that was all hard-coded into the firmware.
If it helps, Flashforge has a reference PDF showing the commands they support on the Dreamer:
http://www.ff3dp.com/#!gcode-protocol/c1zfg
I don't see anything in there about steps/mm or toolhead offsets.
If it helps, my dreamer works fine with the stock S3D profile. You might want to try going to help --> config assistant and selecting the Dreamer profile to re-download the recommended settings.
Posted: Wed Aug 05, 2015 1:21 am
by GergK
Thank you JoeJ!
Im using the stock S3d profile for dreamer.
Could you tell my what version firmware are you using? Maybe I should take a try with that one...
Thanks,
Greg
Posted: Wed Aug 05, 2015 6:18 am
by JoeJ
I've probably had 4 or 5 different firmware versions on there over time and never seen this issue. I think it's 20140821 on there right now.
Posted: Tue Aug 18, 2015 10:47 am
by GergK
Finally I get the solution:
The dreamer's got bad setting in its pulley menu. It was "silver" instead of "Black".
Dreamer touchscreen menu: Tools/Settings/Pulley
The silver setting should be when your machine have metal pulleys, and Balck setting need, when the machine have plastic pulleys. Because these pulleys have different diameter, the machine doing upscale moves...
I hope it will help anybody with same issue...
Posted: Thu Aug 20, 2015 5:24 am
by JoeJ
Good to know! I'm surprised the manufacturer doesn't set the correct default values from the factory though..
