Extruder clogged half way through
Posted: Thu Sep 19, 2013 9:51 am
I had a 40 hr print running and half way thru the print a corner lifted and the extruder was rubbing against the raised portion and then got clogged so when I woke up this morning the part was half finished and now what to do?
Is there any way to re start the print at the failure point to finish?
I was thinking I could measure the distance off the glass with calipers or depth mike, then could cut the part at that dimension in my cad system and that would create a new model to now print at the raised dimension hieght. But how to start a new program at this new hieght? Is this possible?
