Is there a way to prevent this?
Posted: Fri Aug 07, 2015 3:24 pm
This is a screen capture of the tool path building the middle deck of a model of the Eiffel Tower. The middle deck extends out from the tower's support structure, and Simplify3D's tool path for this level starts with the support structure (orange) first, and then proceeds to the outside perimeter (blue).
As you can see, this cannot print properly because there is nothing for the perimeter loops to attach to. But of the toolpath started from the inside and worked outward, there would be. But - how to make this happen?
I have already tried both of the Layer tab's Outline Direction options: Inside-Out and Outside-In. The results for this particular layer are the same for each. What happens is the infill structure is done first, then the outside perimeter loops, and then the bridge loops that connect the outside perimeter to the main structure. What's needed is to switch the order of printing the last two types, but I don't see a way to do this.
I can't find a way to post 2 images in the same post, so my next post will show the complete layer.
