[DONE] Feature Request: Heat management for small objects
Posted: Sun Sep 22, 2013 2:11 pm
Would it be possible for Simplify3D Creator manage the heat generated by printing in too confined of an area too quickly?
Here is a recent example I ran into:
HingeBox at Thingiverse
This printed absolutely great until it got to the diamond shaped nub at the top of the print. Because it was such as small area, it was quickly built up layer after layer, without enough time to harden that it became more of a round shape. The round peg no longer fit into the diamond shaped hole that it was designed to snap into, so the box could not be closed. Is there something that can be done with software when we're printing in very tight areas to give a minimum amount of time for a layer to harden?
