Solid infil not solid
Posted: Tue Aug 11, 2015 7:35 pm
by phantomoperator
Hey everyone! As the title suggests, my solid infil is not solid. Also, my perimeters don't connect. I can stick my finger nail between them and pull them apart. My E steps are correct so do I need to adjust my extrusion with or multiplier? I am running a Bowden setup. My extrusion with is set to automatic and my multiplier is set to 1.00. Any help is appreciated. Thanks!
Re: Solid infil not solid
Posted: Wed Aug 12, 2015 6:50 am
by JoeJ
Yes, you need to increase your extrusion multiplier. It sounds like you are under-extruding everywhere.
As a side note, you may also want to verify that your filament diameter is correct (found on the Other tab) since that also affects how much is extruded. Get the filament diameter correct and then start adjusting the extrusion multiplier until you don't have gaps
