1/2 of 3rd layer is missing if First layer is set to 100%
Posted: Tue Aug 11, 2015 10:32 pm
by jfkansas
I have been noticing this for a while now and finally tracked down where it is happening. I reset to factory and changed 1 thing at a time until the problem cropped up. If the first layer is set to 100 then it happens. Any other setting then it is fine. Even 99. It will also fill in over a hole.
The model is fine, remember the layers are good if set to default settings where the first layer is 90
See attachments.
Re: 1/2 of 3rd layer is missing if First layer is set to 100
Posted: Wed Aug 12, 2015 6:54 am
by JoeJ
can you post the factory file?
Posted: Wed Aug 12, 2015 10:59 am
by jfkansas
Rather not, can I email it to someone?
Posted: Wed Aug 12, 2015 7:42 pm
by jfkansas
I sent the factory file through the support system...
