how do I set the print direction for top layer?
Posted: Wed Aug 12, 2015 8:31 pm
by frankpirz
I'm printing with support. I can set the support layers to print at +/- 45 degrees [support tab]
I can set the infill to print at 0/90 degrees, rectilinear infill [infill tab]
I'm printing 2 bottom layers and 3 top layers [.3mm layer height, 20% infill]
I'd like the top layer to print 0/90 degrees. right now it prints at +/- 45 degrees and I've
been unable to find a setting tab to use to set it.??
slic3r uses the same angles for infill and finish layers. What does S3D do?
BTW, still prints at +/-45 even when I set support to 0/90.
so short of turning my part so that its at a 45 degree angle what do I do?
using S3D 3.0.1
Frank Pirz
Media Conversions LLC
Re: how do I set the print direction for top layer?
Posted: Sun Aug 16, 2015 7:05 am
by CT4
You can do this on V2 but sadly some bright spark removed that feature from V3.
It is something I used all the time now I am stuck with this cross hatch printing. If enough of us complain then they may put it back.
Posted: Sun Sep 13, 2015 10:19 pm
by Max Filament
Please put it back !
Posted: Mon Sep 14, 2015 7:53 am
Who's this aimed at??
Its unlikely the Simplify3D developers will see this thread. You need to raise a thread in the Feature Request section stating the feature needs to be reinstated. Then they'll see it!
