Taulman 910 - Supports too thick with 0.8mm nozzle
Posted: Fri Aug 14, 2015 11:25 am
I've been printing large parts using Taulman 910 using a 0.35mm nozzle, which was stock on my PolyPrinter 229. While the parts looked good and support was easy to remove after some tweaking, the parts weren't quite strong enough compared to what I expected. I contacted Tom over at Taulman and he suggested using nozzles between 0.5-0.8mm to get the best strength, with the 0.8mm nozzles producing the stronger parts.
I started using a 0.8mm nozzle and wow, the parts were SOOOO much stronger. I noticed some issues with stringing and blobbing, which I addressed pretty easily, even though they were easily removed from the parts. The issue I'm having now is that the support structures are so thick that they are very hard to remove now. They are both thick (around 1.1mm), strong and are bonding to the part on the dense support layers.
Do any of you know of a good trick to use to print the support structures in a way that they will remove from the part easier but still provide the structure needed for large, detailed objects that require large amounts of support? I could maybe bump up the support structure underspeed but I want to make sure that I don't go too fast or the material can be under-extruded and come out all fuzzy and not provide good support. Currently printing at 24% for Outline/Infill of max 250mm/s speeds. Supports printing at 30%. Also, I have the extrusion multiplier at 1.00 since I still want to make sure I'm not under-extruding for the body of the parts.
Any good suggestions before I start printing again to avoid wasting too much of the 910, which is expensive to experiment with too much? Thanks everyone!
