What settings bring my lines closer together?
Posted: Sun Aug 16, 2015 8:11 pm
by jamsessionein
I'm noticing some gaps in the top layers of my models, but I don't think it's necessarily a printing failure - I think Simplify3d is slicing the models that way.
This seems borne out by the fact that on multiple prints, the pattern on the top layer is basically the same.
I'm using a .35 nozzle and the following settings:
Any ideas what I should be tweaking here? I feel like if I manually turn up my extrusion modifier it just obliterates the details.
Re: What settings bring my lines closer together?
Posted: Mon Aug 17, 2015 5:50 am
by JoeJ
You need to adjust your thin wall settings. Post your factory file and it will be easier to tell you exactly what changes to make (file > save factory file)
Posted: Mon Aug 17, 2015 7:24 am
by jamsessionein
Aye aye!
http://www.fusedcreations.com/adam/240_badge.factory
The only thin wall settings I see on the 'advance' tab seem not to actually affect this.
Posted: Mon Aug 17, 2015 7:53 am
by JoeJ
Go to Infill tab, change outline overlap to 30%. It looks much better after that.
Posted: Mon Aug 17, 2015 8:12 am
by jimc
the problem here is the space ir gap is too narrow to put an extrusion in. Joe's recommendation is good and may work depending on exactly how narrow that gap is. If it were me i would reduce the amount of perimeters by 1. This will allow a bigger gap that the printer can put a top layer infill in. Anything with text on a top surface i usually try and do just 1 perimeter. It just makes for better top surfaces in detailed areas.
