Not able to print a part where Cura and Repetier do
Posted: Mon Aug 24, 2015 6:02 am
by marcnotenboom
I try to print a thin walled item. Only if I set my nozzle to 0.1 I am able to slice it correctly. But it will not print as my nozzle is 0.4. :roll: With Cura and Repetier it is no issue as they automatically seem to increase wall thickness. So I have to use these programs all the time.
What it the trick for Simplify3D to do this???
Re: Not able to print a part where Cura and Repetier do
Posted: Mon Aug 24, 2015 9:17 am
by KeyboardWarrior
marcnotenboom wrote:I try to print a thin walled item. Only if I set my nozzle to 0.1 I am able to slice it correctly. But it will not print as my nozzle is 0.4. :roll: With Cura and Repetier it is no issue as they automatically seem to increase wall thickness. So I have to use these programs all the time.
If your walls are too thin that would be an issue, I'm not sure how Cura or Repetier slice thin-walled objects, but I know Simplify3D works best when the walls are larger than your nozzle diameter, so in this case >.4 mm. Can you post a factory file of this, by going to File ->Save Factory File As.
