Sirnicha
Amount of separation layers depending on steepness
Hello!
At (nearly) flat surfaces wich are supported I need at least two separation layers between support and part to get the support easily off.
At steeper areas I need to switch the separation layers to zero, otherwise the outlines of the part curl due to not enough contact between support and part.
Actual at parts with variable steepness areas I switch the separation layers to zero to be sure that nothing curls. But the separation at the flat surfaces is than a mess!
Adding several processes isn't really a solution, because sometimes I have steep and flat areas at the same layer hight, additionally its a big effort.
It would be very nice if there is a function that recognizes the partial steepness of the part to change the amount of the separation layer automatically!
Thanks,
Felix
