Probably due to some setting I have made, what setting are a good starting point. Also where can I locate the Brim settings.
Be careful though because if your value is too big it will warp and separate mid print. After a lot of tinkering, 0.20 seems to work well for me. However, if it is going to be a large print sometimes I will lower it a bit just to make sure it stays together.JoeJ wrote:Increase the raft "separation distance". Larger values will make the raft separate easier.
