Replicator 2x
Posted: Mon Oct 07, 2013 9:09 am
by Peronet666
Wot do i do wrong
I get this can not connect to my makerbot
Attempting connection at COM1...
Attempting RTS reset and trying again...
Connection failed.
I got Firmwware 7.5
I have put the Firmware Configuration to Sailfish/MakerBot Firmvare
And Add FFF Setings To MakerBot replicator 2X
Pls Help Me
Re: Replicator 2x
Posted: Mon Oct 07, 2013 2:51 pm
by dalew8abz
Hmmm... Perhaps check the port and baud rate on the Machine Control Panel. Does your USB connection to the printer really show up as "COM1"? Tap the arrow to the right to see a list of possible ports. Also, does the printer expect 115.2 kBaud, or 230.4 k, or ????
If you still can't connect, probably best to contact S3D support via the "support" page on the main website.... or e-mail to [email protected] .
Good luck!
Dale
Re: Replicator 2x
Posted: Tue Oct 08, 2013 5:21 am
by Peronet666
Hi
Thanx for helping me Dale
I have done as you said then I found the printer :-)
But I still get no contact with the printer.
I get this message
Attempting connection at COM4...
MakerBot printer detected!
MakerBot printers currently use the SD card for direct printing.
For additional details see: http://www.simplify3d.com/support/makerbot/ (I can not find anything that helps me hear)
The printer is on the COM4 Baud Rate 115200
I have downgraded the software in the printer 7,4
Do you have any more ideas ?
Sorry for my bad English
Re: Replicator 2x
Posted: Tue Oct 08, 2013 7:40 am
by jimc
You should just email support
Re: Replicator 2x
Posted: Tue Oct 08, 2013 9:03 am
by Peronet666
I did get this answer from suport.
If anyone else has the same problem.
So i will be fixt :D
Right now the software will create a .x3g file that you can copy to the SD card on your Replicator 2X. You can then print that file by using the LCD menu on the front of the machine. You can find an extensive guide here:
The next software update will be adding extensive direct USB control for these printers. We have been testing it for the last few weeks so it should be available shortly.
