JoeJ wrote:If that error message keeps popping up in down in their software, then it's probably an issue with the spooler. It works fine for me.
Perhaps it's some kind of issue spaces or characters in the filename that the spooler can't handle. Or maybe also a permissions issue where the spooler can't see it. Try to export the file to an easy location like your Desktop and use a simple filename like test.gcode.
I actually hadnt seen the spooler before. I was trying to load the file into the standard interface. I found an article mentioning the spooler and got it working that way.
One thing though, once in the spooler it asks if I want to use M3s pre-processer. Does that mean it would have M3 create the support and other things that were already created in simplify3D? So I should say no to that?
