Large objects not opening..
Posted: Sun Sep 13, 2015 3:10 pm
by GBR1
I am new to S3D, been using Cura for a few years.
I have some models which I designed and I know fit on my build plate. They are not oriented correctly in my CAD but that never botherd me before as I simply opened the STL in cura and then re orientated it.
In S3D it won't allow me (or doesn't appear to) load files that are outside the build plate. Is this correct or do I need a different setting somewhere?? I just get "can't auto arrange, largest part exceeds build dimensions"
The STL files in question open fine in Cura..
Many thanks
GBR1
Re: Large objects not opening..
Posted: Sun Sep 13, 2015 3:55 pm
Try unchecking the "Auto arrange..." option on the models tab of the Options (in Tools) and then see if you can load the file.
Posted: Mon Sep 14, 2015 1:48 pm
by GBR1
Thanks, I tired that but no joy.
The problem seems to be as its to big for the build plate in the XY, it scales in as 9999mm!?
As said in Cura it opens and then I rotate it and it fits fine.
Can anyone else open a object thats too large for the build plate and then scale it/rotate it to make it fit the build plate?
Cheers
GBR1
Posted: Mon Sep 14, 2015 1:55 pm
by JoeJ
I open big models all the time and then scale them down in the software. Works fine here.
Can you post your STL file?
Posted: Mon Sep 28, 2015 12:12 pm
by MIKET
is there a way to adjust the size of the build plate in the software to match the dimensions of the flashforge creator pro build plate?
Posted: Mon Sep 28, 2015 1:04 pm
by JoeJ
Just go to Help > Configuration Assistant, and then select the FlashForge Creator Pro from the list. Then everything is configured automatically.
Posted: Mon Sep 28, 2015 1:12 pm
by MIKET
JoeJ wrote:Just go to Help > Configuration Assistant, and then select the FlashForge Creator Pro from the list. Then everything is configured automatically.
if i'm choosing to use one extruder do i choose Flashforge creator pro or creator pro single, or does it matter? When using dual extruders do i choose creator pro dual. Little confusing.
Posted: Mon Sep 28, 2015 5:44 pm
by JoeJ
If you purchased the creator pro, then choose "FlashForge Creator Pro". It will then download the settings for that machine, which include options for printing with the right extruder only, left extruder only, or both extruders. So after you finish the wizard, click "Edit Process Settings" on the left and then you can choose the appropriate "Auto Configure Extruder" option (in your case, you want to configure for right or left extruder only if you are only using one nozzle).
