iPa64
Filter for communication
Wed May 20, 2015 2:19 pm
That should be useful to have filter for communication log, filter for especially M105 command.
(Octoprint have this feature)
That help to mask no relevant dialog, when you are waiting for a reply from a command ( like G29 for Autobed).
Re: Filter for communication
Thu May 21, 2015 4:55 am
You can turn off the verbose checkbox and then it doesn't show things like M105 responses
iPa64
Fri May 22, 2015 5:13 am
I have tried but there is a lot of information missing with verbose unchecked, not only M105. With G29 command main useful informations are missing.
I have tried with M48 X50 Y50 V4 ( repetitive test for autobed probe on Marlin firmware).
Samething don't get any information with verbose unchecked.
sixdeuces
Command filter for communication panel
Fri Sep 18, 2015 12:12 pm
With the "Verbose" option checked, the constant updates of the temperature requests (M105) flood the log. Without Verbose, I can't see the responses from the microcontroller. A simple filter option (like Repetier has) to remove the temp requests would help a lot. Even better would be a customizable filter, allowing you to specify which commands to hide.
Beta
Re: Command filter for communication panel
Thu Jul 12, 2018 8:20 pm
Agreed, the communication log is mostly useless. If S3d would just stop sending M105 all the time, then it would be somewhat useful.
