Out line overlap %
Posted: Mon Sep 21, 2015 11:51 am
by Rebekah_harper
I was wondering if a Outline Overlap % could be added.
I was looking for something so that If I have a overhang that is 1mm that I could use 3 outlines from inner to outer which I could overlap with out having to use support material.
Ideally as part of over hang function where if I had the 1mm overhang the stretch 10mm along that I could set 50% overlap which either I have to set myself to 5 outlines or it automatically calculates the amount of outlines requires to cover the over hang.
further more as a continuation from that a layer count to be set so that it would do the required number of outlines on the over hang for x amout of layers before it would use the normal layer settings.
so I could end up with 5 outlines for a 1mm over hang for 3 layers then after that it could return to normal layer settings of 2 outlines.
