erniehatt
Stringy Bits
Hi, probably a stupid question, but is it possible to stop the stringy bits from forming across empty spaces, I have tried a few things but they dont seem to do any good. Ernie
wfcook
Re: Stringy Bits
Try this on the extruder page
Retraction ON, set it to something like 2mm to start. I use 3.5mm but this depends on your hotend\
Retraction Speed: 25mm
Coast at End ON: 0.8mm - this is the magical setting
Wipe Nozzle OFF
Re: Stringy Bits
Just a footnote......note that the preview will now appear to have lots of small gaps in the extrusion. This is actually where the coasting is taking place!
It had me foxed when I first used coasting.....until I realised exactly was happening. ;) ;)
erniehatt
Re: Stringy Bits
Thanks Fella's, for the help appreciated. Ernie
erniehatt
Re: Stringy Bits
[quote="wfcook"]Try this on the extruder page
/quote]
Was this a typo, because the figure did not work for me, in another post I was told that this would not work, and it was correct. 3000 was a better figure to use. Something else I have learnt.
Re: Stringy Bits
I do believe the above suggestion for retraction speed was 25mm/sec...... and if you have your speed setting in Tools/Options set to mm/min, then you'll need to set the retraction speed to 25 x 60 mm/min...ie 1500 mm/min.
erniehatt
Re: Stringy Bits
Thanks for explaining that Doug , something else I've learnt.Great place this forum.
