Since 3.0.0 or 3.0.1, there has been a new undocumented "feature" where infill and skirt are printed with 200% (estimated but pretty obvious once you play with it) speed. This is uncontrollable and there is no corresponding setting in the Process settings. This causes very jerky movement during infill and just because of this, we had to reduce the printing speed to 3000mm/min. With 6000mm/min, it is murder on the machine. We're on the Leapfrog Creatr HS but shouldn't matter.
Can anyone confirm this? Is there any workaround?
