I let the filament cool down for a while, and it didn't get any thinner. I think I need to test different settings to find out which one is best.jimc wrote:plastic extruded in the air being larger than nozzle is normal. That is called die swell. Every ppastic formula is different. I have done some that gets really big and fat. Its basically shrinking back as it cools.
bapro wrote:There´s probably nothing wrong with your equipment. You can´t make any conclusions on what happaens when you print into air. You have to build a single wall cube and measure it.
Well, I measured the support element, which just one line and it was 0,5mm thick also.bapro wrote:There´s probably nothing wrong with your equipment. You can´t make any conclusions on what happaens when you print into air. You have to build a single wall cube and measure it.
