I just installed 3.0.2 for my K8200.
I have got a strange blobbing problem with it.
When starting a new loop/layer it retracts way more than is set (around 1.0-2.0mm) . It retracts several centimeters
and then it extrudes way to much when starting the layer/loop. So i get really large blobs everywhere, and the head bangs into
those blobs and ruins the print.
If i use 3.0.1 with the same profile it works as normal.
I have checked if it was the "relative extrusion" setting, but they are the same when running both versions.
All other settings are also the same.
What could be the problem?
It starts with the first infill layer in this file.
